Hi expert,
I need your help. I use internet but its speed is really slow. Is there any way to speed up? I heard about a software which help a bit in this regard. Is it true? If yes, how I can get the best and free internet speed up lite. Please, tell me in detail as I can get it and use it.
Thanks
How can I get the best and free internet speed up lite?
There is a freeware program that configures your modem for fastest connectivity and promises to have better performance while surfing the internet. However if it is the ISP's issue or internet line issue you will not see much difference in performance. You can download this program through this link http://internet-speed-up-lite.smartcode.com/info.html. I hope it helps
Regards
Hi Zubin Lennon,
Thanks for raising an issue which is a common phenomenon for a lot of us.
Yes, Internet speed up lite software does help the internet to speed up a bit.
There are a few options from where you can download the Internet speed up lite software as a freeware. It has the capability to boost & optimize the performance of the internet with the set of tools.
It also claims to enhance the security.
Please find the below given link from where you can download the Internet Speed up lite.
1. You can download it from here where you will also get a user review option.
2. Another option for you to try this link here.
Hope this tool will help you to optimize internet performance.
Thanks & Regards,
DBD
