How can I get the best monitors with netgear builtin soft?
Hi expert,
I need your help because I am facing a problem.
I want to use the monitors with netgear built in soft, but I cannot find it.
Please, tell me in detail as I can find the mentioned software easily.
Please, give me a link from where I will be able to download the soft free of cost.
Thanks
Best Answer by Davidson Mudge
Answered By 5 points N/A #148913
First of all, you forgot to mention the model of your monitor so we can determine the correct software that you need.
Look for the model name and go to the Netgear official website and search for the software that you need.
Click the link below and then select the For Business tab and then click on Software.
http://www.netgear.com/home/
Answered By 0 points N/A #148914
Hi Leslie,
Netgear has various products, thus finding a specific tool that you want may be tedious as you have to consider a lot of things.
You have to check the technology and the way your network is set up. You can go to the Netgear Download Center page and type the product name and model number of your monitor to search for the appropriate driver. The link is below:
https://www.netgear.com/support/download/
