How Can I Get Convert HTML Code To Text?
I want to get the HTML code from a website and store it like a text type of file so that it makes a way for me to refer to it afterwards with any other HTMLl editor and if required I can copy some parts of the code. How can I convert HTML code to text?
Answered By 55 points N/A #84338
To get HTML code of a website you need to open the required website on chrome or firefox and press Ctrl + U to get the HTML code of the website and to save it as a text file you can copy the whole code by selecting the code. And then opening the notepad app on your computer by using the run command.
After pasting it to notepad by pressing the keys Ctrl + V you can save it to any location you want.  
