Hi expert,
I am facing a problem and it needs to be solved. I use windows 7 as operating system. I need a registry cleaner software for it.
But I don’t know which one is the best.
Please tell me how I can get an easy registry cleaner for my windows 7.
Thanks in advance
How can I get an easy registry cleaner for windows 7?
Hi Larry S Montelongo,
There are lots of registry cleaner in the market which claims to be free but actually charge in different stages of its operation. I am only going to give you a list of registry cleaner which are absolutely free in any stage.
1. Best freeware you can have as a registry cleaner is Ccleaner which supports Windows 8, Windows 7 and other Windows OS as well. You can download it from here which is their official website.
2. Another top notch freeware registry cleaner is JetClean which also support Windows 7, Windows 8.
Always download it from their official site here.
3. You can use Easy cleaner which is one of the oldest utility out there in these segment. It has support for different languages & ofcourse supports Windows 7. Here is the official website.
Please note registry cleaner is good for repairing/removing unused registry. Always try to download from their official website. Its not a security tool which will protect you against any kind of virus.
You need to use good anti virus as well.
Thanks & Regards,
DBD
Download CcLEANER form internet it has a in-built registry cleaner.
So clean by this software is not too risky for registry else i have tried some bulky software for registry always they clean my windows registry and i have to reformat my pc but with Ccleaner registry cleaner i don't need to do that thing
So download Ccleaner
