Ryan Abate
30 points
Posted on - 03/23/2013
Hi expert,
I have the motherboard cd which was provided with my motherboard. Now I need to install ga 7vkml audio drive on my pc. How can I get it free of cost? Please, tell me in detail as I can get my desired app as easily as possible.
Thanks in advance
How can I get the ga 7vkml audio drive free of cost?
Hi Ryan,
You Didn't tell me which type of XP you installed in your PC. By the way, i give you all versions download link, i hope your problem will be solved.
https://driverscollection.com/?H=GA-7VKML-P&By=Gigabyte&SS=Windows%20XP
Goto the above link and select your OS version under the "Choose your OS" tab. Then download the audio driver.
Thanks for asking.
As it seems you are having gigabyte GA-7VKML motherboard which has the Realtek 201A AC'97 audio chpiset on board. If your motherboard cd driver doesn't have the audio drivers inside you find them and download them for your computer through this link http://www.realtek.com.tw/downloads/ . This will navigate you to realtek's official website in the download section where you can download and install your audio drivers
