mitzi lu
10 points
Posted on - 04/02/2012
Hello users,
I recently have downloaded no$gba and whenever I try to run a rom, an error message popped up . This error message mainly about something related to the procedure of getting the gba BIOS.
I am looking forward to getting that, can anyone help me out?
If there is no way to get it, can you suggest easiest way to use DS emulator by any means?
Thanks in advance. Help will be appreciated.
How can I get gba bios for DS emulator software?
Hi Mitzi Lu,
    This probably occurred because you are missing some of the files needed in order for it to emulate properly; however, Nintendo DS bios files are not needed anymore in this emulator since it has sufficient properties to emulate properly. The files needed were posted in their site. Here is the list:
1.      GBABIOS.ROM
2.      DSBIOS7.ROM
3.      DSBIOS9.ROM
4.      FIRMWARE.BIN
Nonetheless, you should put all of these files in your no$gba folder. It should probably work; however if it still will not work, I suggest you use another Nintendo DS emulators like DeSmuME and iDeaS. They are pretty good to try. Hope it works.
->>Mathew Joni<<
