Hi expert,
I heard that I mcafee foundstone has been released on March 18, 2013. Can I update my previous version with the new version or I need to take a fresh one? Please, tell me in detail as I can get the software easily.
Thanks
How can I get the MCafee foundstone software?
Hello
You can download it and install as you installed first version but there is easier way. If you want to update your software to newer version you need to go to Start menu, then select Programs -> FoundStone and then click on Update McAfee Vulnerability Manager. Now you will see dialog which will tell you how to update your software. I hope I helped. Regards.
Hi Matthew,
Before you can go and install the Foundstone, you must first check if your business would be eligible for the support.
Experts will run test and make sure that your papers and the flow of the business will not be affected with the test.
They will of course schedule the test to avoid possible downtime.
And they will be the one to tell if you are eligible then they will prepare necessary papers.
You can start using it a week after the engagement. Check their FAQ here.
