How Can I Get My Printer Online
I have to print my documents daily. Before I used to do it from the shop but now I am planning to buy a new printer. How can I get my printer online?
Step 1: Turn off your printer and then again turn it on to reboot it.
Step 2: Connect your printer to your computer and it should have connectivity.
Step 3: Click Start then Devices and Printers", then “See What’s Printing”.
Step 4: Select Printer and then “Use Printer Offline”.
Step 5: Return to Devices and Printers after closing the print spooler window.
Step 6: Download the driver for your printer.
Step 7: Click Start button and then Control Panel.
Step 8: With the help of Search box, find troubleshooter. Step 9: After choosing Hardware and Sound, click Use a Printer.
