How can I get net connection in PC through Mobile
I can get internet in mobile. I am already installed Nokia PC suite for my system
Contacts, photos, messages are also synced between devices
Which settings are needed to add for net connection?
Hello Ayswaria,
Once you have the PC suit software installed, all you just need to access the internet on your Nokia phone is to contact your mobile network service provider and ask them to send you the configuration settings for that particular mobile phone type and the line you are using. Usually there is a shortcut for that, whereby you send some message to the service providers using a certain number and then they will send you the settings in form of a message and then you will be required to accept the settings and save them on your phone.
Therefore just call the customer support of your mobile service provider and then inquire for the procedure that you will need to follow so as to get internet settings on your phone. They may ask you about the model of phone you are using so have that information ready.
__
Regards
Clair Charles
Most cell phone nowadays is Wi-Fi ready and or has the ability to use the Internet using the actual units. This so-called smartphones are now designed to connect to the Internt by the use of there fingertips.
Nokia units also has the capability to connect to the Internet only if the unit itself has Wi-Fi ready features. You can also use the 3G online access to make use of the Internet.
It doesn't require you to install an app on the actual unit to enjoy the Internet access, because installing an app on the cellphone also needs Internet access. Most cellphone has pre-installed software, a software used for Internet connections. This regardless what type of Internet connection you are going to use, 3G, 4G and of through pre-built-in Wi-Fi card installed.
In order for you to get connected to the Internet, you need to communicate with your mobile provider and or Internet Service Provider. You can also connects to any Wi-Fi ready establishment that broadcast wireless connection for free. Some uses encryption code and some prefer not to use wireless password.
For pre-paid cellphones, you need to have an extra load as payment of Internet usage per bits needs and or postpaid type of Internet.
You Nokia phone should have support for internet connection sharing or internet connection tethering. This will allow it to direct the internet traffic from the mobile phone itself to the computer. Make sure you have the latest Nokia PC Suite version installed in your computer. Open the Nokia PC Suite application and click on Connect To Internet which should be one of the icons displayed. Make sure GPRS is activated and connected in your mobile phone for this to work. Make sure you also have the mobile phone located in an area where the signal from the network is good. Most of the time the cable used to connect to the computer is quite short which may make it difficult for the mobile phone to get a good signal due to its location.
