How can I get the netapp capacity calculator soft?
Hi expert,
I need your help. I am searching for a netapp capacity calculator soft. I am trying to find out a free one. Please, tell me how I can get the soft easily. Please, don’t forget- I do not want to buy it; I need it free of cost.
Thanks in advance
Best Answer by Davidson Mudge
Answered By 0 points N/A #168869
Hi Marian,
I have a website for you that helps you to download a free software of Netapp Capacity Calculator.It install just in seconds for Windows XP, Vista 7 and 8.Here is the link that can helps you on your problem,netapp-capacity-calculator.software.informer.com. I hope it can give you the things what you need to pursue what you are doing.
Answered By 0 points N/A #168870
Hi Marian,
I found you a stand alone file that is compatible with Windows OS. It does not need an installation.
Since it is developed by a freelance programmer should you find any bugs you can send him a feedback.
This gives you an estimate number so you have to expect that it may not give you the correct capacity.
Click here to know more.
Another software is from Software informer same as the first one this gives an estimate of the capacity.
This is a free software and same as above you can send feedback for them to improve the tool.
