Hi expert, Â
I use different animated wallpapers in various purposes. I like it very much. But my collection of animated wallpaper is very poor. Can you help me in this regard? Please, give me some links from where I can easily get new animated tornado wallpaper.
Thanks in advance
Kristopher Fran
How can I get new animated tornado wallpaper?
Dear Kristopher,
You can go to some online store which have got plenty of wallpapers. It’d be better if you’ve mentioned about the device. Is it PC or handset? If you need it for your handset then you can try the link below:
https://www.mobango.com/
Just type animated tornado wallpaper in the search box and select your device. If it is for your desktop, Google has a lot of animated wallpapers.
Good Day.
Hi Kristopher.  Is your device a handset or desktop ? Because I searched all over  the internet, if there's an animated tornado wallpaper, I found one that it is for a desktop. And here's the link that you can download, and just look at the description. If it is handset I found some links of animated tornado wallpapers link1, link2, link3, link4 and you can download them and save it to your handset.  Best regards.
