samsul alam
Posted on - 09/27/2011
I found some Malware in my win32 folder and I deleted stuff like crazy (dumb move) and now my computer won't load to login.
I pressed F12 on reboot and try to load defaults but when I press, Enter it states, "factory default acknowledgment " and does nothing. I want to know how can I get rid of this problem?
How can I get rid of “factory default acknowledgement”
Win32 is a core interface which is used by Windows to communicate with the program. Without it a program cannot communicate with Windows. So it is of much importance for the system.
As you said you have removed this file that’s why you’re unable to start Windows. There are several possible solutions for this.
Try with Windows recovery. Insert your windows CD and try to recover your system so that it may work fine. I hope it will work.
But if it doesn’t work, well then you have to install a new copy of Windows. Insert windows CD and boot from CD and follow the instructions.
