How can I get some flash fire Fla files
Hi, I need some files to flash files to design as fire Fla to get some flash fire Fla files. How can I acquire mega fire Fla in flash as easy?
Good day Hylon
You can visit https://www.deviantart.com/resources/applications/flash/whats-hot/?q=flash%20fire where you can download fire effects, some of them have tutorials step by step.
Another place you can generate your custom fire flames and generate the flash files is http://www.dvd-replica.com/kozykorner/flash-comfire-1
You can design your own and fire.
Below are my parameters to create my fire flames.
I click on the generate lash files tab. This will pop up.
That is my fire flames I created, right click on the links "Save target as", and download to your PC to incorporate it into your website.
