Hi to everyone,
How can I get an update for Huawei s7?
I got my table Huawei s7 and don’t have any idea about the important updates needed to be applied.
I want it to be virus free.
If there is some configuration that needs to be set up please let me know.
Thank you.
How can I get an update for huawei s7?
Huawei is a good tablet and actually quite economical too. It provides quite a lot of features at a low price.
For updates you'll need to download the update files first and foremost.
To download the files visit the link:
There is a link to the tutorial too in the installation process.
Hope I helped thanks!
Hi Maratha,
You can go through the following steps to update your device.
Go to Menu > Settings > About phone > System Updates.
If there are any new updates available for your device, the update will start automatically.
Else you will be shown a message that "Your system is up to date".
Make sure you are connected to a WiFi system while updating as you may have to download large files which may be chargeable if you download it through your network.
Hope this helps!
Drianna allen
