Hallo people!
I bought a webcam for my work and I am expected to have a connection with my boss' office so that he can monitor everything that I do in the office. Is there an application that can be used for streaming personal webcams? This should also have a recording option so that whenever he is not in the office everything can be recorded for him to watch later. Thanks a bunch.
How can I go about streaming personal webcams?
It is relatively easy to achieve your objective through the following means:
iCam- an application that lets you view ongoing video streams to your web browser or phone(including iPhone and android gadgets). Whenever it senses/detects a motion it sends a direct notification to your phone immediately. Additionally, it takes quick snapshots for you to view later. It is cheap. Unfortunately, it can’t store streamed videos.
WebcamXP- this ranks as the most user-friendly application I have tested. It is quite easy to set up. It also lets you schedule your recording sessions- when and where, and also lets you specify how often you require the videos uploaded. It is however more expensive.
There are various software’s that are used with webcamera and try to use manycam software which is downloaded from www.manycam.com. It’s useful to chat and watch videos using a web camera. It supports live audio effects and d the life changer. It supports the custom animations and has also features that can help you change voices
