How can I have an anarchy text symbol copy for Facebook?
I want to have an anarchy text symbol copy for my Facebook, but how can I have it? Any help would be greatly appreciated.
Hello Roya,
Do you know Charmap (or “Character Map”)? It’s a program built-in into MS Windows operating system. You can use it to input or check out characters of different encodings and fonts installed on your system.
How to access it:
· Start > All Programs > Accessories > System Tools > Character Map.
Another way or the faster way is:
· Start > “search bar” > Type “Charmap”, then press Enter.
After you've access the charmap/Character map check the advance view, then at the group by select Unicode Subrange for easy viewing. Now enjoying looking symbols. I hope this helps.
Hi Roya ,
The Easiest way to do this is to use a built in Windows Program called Character Map , You can find this by going to Start > Accessories > System Tool > Character map
OR by Clicking start and entering Char Map into your Search bar
Hopefully this will fix your problem , Good Luck
