Iamatechy
200 points
Posted on - 07/13/2011
Hi techyv experts,
How can I hide am icon in iPHONE that's a default one? I have the Youtube icon, that I want to hide or delete or remove from the main screen.
is there a trick that can do this?
Thanks in advance.
Scot1984
15 points
How to hide default specific iPhone icon
To hide unwanted icons on your iPhone device, simply press the icon until it shake. Drop it to another unwanted icon to create a folder. Repeat the same process until you put all the unwanted programs on a folder. When done, tap the title of the folder and change it to Unwanted Programs. Click the home button to close it.
A great application, that will help is SBSettings. It is designed to help you control, what is displayed on your iPhone. Its main feature and the most useful one is to hide apps which you require.
On BigBoss section of the Cydia App Store, SBSetting is available. In the app you have the option of 'Actions' in the main menu and in the dropdown mode you have 'More' at the bottom.
This is the menu to control and then you can Hide Icons
Hide iPhone Apps
