Voldemort
20 points
Posted on - 08/20/2011
techyv expert I have come to here for a simple problem of my laptop hard drive.
I have some personal document in my hard drive which I need to keep safe. I have tried so many times but I could not hide my hard drive.
My laptop details is given below-
Dell Inspiron N5010
320 GB Hard disk
2.63 GHz Intel Core i3 Processor.
2GB Ram.
If you can solve my issue then I would be grateful to you
MorganK
How to hide my Hard Drive?
You can completely hide the required drive or drives and it will completely remove from your computer. Then no one can see this drive from command prompt, safe mode or through My Computer.
Moreover, if you want, you can see the drives at you discreet
You can do this by modifying your registry. Please follow the below steps;
Go to start > Run and type regedit
Now you have to navigate the following registry as in the following way;
HKEY_LOCAL_MACHINESoftwareMicrosoftWindowsCurrentVersion
PoliciesExplorer
In the Explorer go to New and in the expand menu go to DWORD Value
In the Edit DWORD Value dialog box, put the value name as NoDrives and put Decimal in Base
In Value data, put the drive value, which you want to hide (E:16, D:8, C:4)
When you restart the computer, you will not be able to see these drives
If you want to make visible the drives put ‘0’ in NoDrive
Thanks
Morgan
