How can i hide nod icon in taskbar
I am using nod antivirus in my laptop, i want to hide nod icon in taskbar, but i am not able to do so an anyone help me to solve this problem.
Hello Alberto! Good Day!
What is the operating system your using? This works in Windows 7 (not sure in XP) on hiding icons in taskbar.
How to do this.
1. Right Click Taskbar > Click Properties.
2. Look for Notification Area, Click customize.
3. Look for the Nod Antivirus icon, then change its behavior setting to "Hide icon and notification"
4. Click OK.
Hope this helps!
Hi Alberto!
If your problem is how to hide nod icon taskbar I share with this link https://itstillworks.com/install-volume-control-taskbar-7439121.html .It’s a kind of forum where you can have valid steps to perform. You can also try this link https://www.computerhope.com/issues/ch000734.htm to learn about the step.
Thank You!
Notifications
