How can I import new theme for Zend studio?
I want to use new theme in zend studio. I heard about the dark theme. Is it well to use? If you know any new one better than this, please tell me how I can import the new theme.
Thanks
Thanks
First save different themes to your computer then go in your Zinda studio/software, Go to “File”>Import, right there click on “General”>”Preference”, click “Next>” there and then browse for your saved themes and select your file then “Import All” and Finish. And if you are using“Eclipse way” you can change the color manually for darker color .Go to Windows > Preferences the clicking General > Appearance select Color and Fonts. And start change the color manually the way you want.
