How can I improve my video quality?
I am using a computer of Pentium 4. Currently my video quality is not up to the mark. Now a days the games and movies are developed in highly video effects like HD or 3D which sometimes don’t support in my computer. My current requirements are as follows:
Pentium 4 CPU 1.80 GHz
256 RAM
Motherboard serial – D845GEBV2
Now what can I do to improve my video quality which will support all modern video effects?
Which Video Card is suitable for my PC?
Best Answer by Tony clever
Answered By 20 points N/A #90113
There are lots to change. Pentium 4 CPU 1.80 GHz, 256 RAM is not enough for create highly video effects like HD or 3D. Pentium 4 is ok but processor speed should be up to 2.66 GHz. CPU 1.80 GHz will be alright if you add a graphics coprocessor with it that’s mean Video Card. Your motherboard serial is D845GEBV2 so you can add Nvidia-Launched-GeForce-7950-GX2-Graphics-Card for this condition.
It will help your computer to play high quality games and movies in highly video effects like HD or 3D.
Also don’t forget about your RAM. 256 are too low for these days. Now 1 GB is necessary for all condition.
Answered By 0 points N/A #90114
Hello Mustaf,
Improving the video quality of your system which build with motherboard Intel D845GEBV2, Pentium 4 1.80GHz and 256 memory used. As checked motherboard D845GEBV2 consists of two type slots for video card which are PCI slots or AGP 4X slot that can be used one at a time. Keep in mind that PCI slot and PCI Express slot are different.
With this Intel D845GEBV2 motherboard we used a video card for AGP 4X slot instead of PCI slot because PCI video card are expensive and manufacturing production is lesser.
We recommend the Intel D845GEBV2 motherboard to used video cards like GeForce 7600 GT 256MB AGP, GeForce 7600GS 512MB 128-bit GDDR2 AGP,ATI AMD Radeon HD 4650 AGP 512MB GDDR3, and Stealth S120 AGP 256MB DDR. It’s true that the recommended memory used of your motherboard Intel D845GEBV2 is only 1GB.
