How can I increase Virtual memory?
Virtual Memory is the concept of using the Hard disk space, for temporary storage of running programs.
The virtual page size can be changed depending on user requirement, if there is free space available on C drive or the drive, where the Operating system is installed.
To change the virtual memory space, follow these steps.
Hope this helps.
Missy
Virtual Memory is a paging file that uses a certain area in the hard disk that can be use as extension of RAM. It serves as an extension of your computer's memory space and it can be manually changed or you can let WINDOWS specify its automatic settings.
Here are the steps is changing and allocating Virtual Memory settings:
1. Press the Windows LOGO key + Pause Break on your keyboard simultaneously
2. System Properties will pop-up, ( click on "Advance")
3. Click on "Performance"
4. Performance Option will pop-up, ( click on "Advance")
5. Click on "Change", under the "Virtual Memory" box at the bottom.
6. Choose what drive that you want to change the Virtual Memory, ex. drive C or drive D
7. Put a bubble in the "Custom Size" , and set your desired amount of memory to be used as paging file.
Initial Size: ________________
Maximum Size:______________
Note: The Initial size should not exceed the amount of your Maximum size and the amount should be put in your Initial size should not exceed your total amount of hard drive space.
Trick: The amount of your Initial size and the amount of your Maximum size should be the same for better performance.
Example: Initial Size = 1000mb
Maximum Size = 1000mb
8. click on "Set"
9. click on "Ok"
10. Restart your computer to apply your changes.
