How can I increase zte cdma speed for modem?
I am using a Zte modem with cdma technology. How can I increase zte cdma speed for my modem for fast access to the internet? Assist
You can use an Internet speed boosting software to increase your ZTE modems speed. Please follow the links posted below to access the download pages of several web sites.Â
Hi Christina,
You can definitely give a speed boost to your ZTE modem with CDMA technology while downloading and using the following software.
http://speed-up-modem.software.informer.com/pages/2/
Basically net speed depends upon your ISP data traffic. If its traffic is large it would affect the bandwidth however once you start using the software hopefully it would take care of required bandwidth on a happier note.
Trust this helps.
Baker
