How can I install activex for Mac osx?
I need your help to install activex for Mac osx. Please, tell me the easiest way to do it.
Thanks a lot.
Thanks a lot.
To install ActiveX on your Mac by the easiest way follow these steps its simple.
1. Open internet explorer or launch it by clicking on it.
2. In the resources section click on the download provided links.
3. Click on the download tab and the next window will appear of downloading Activex.
4. When it is completed just double click on it and the installation process will start by itself.
Hi Donna,
That's a good question you have asked and indeed solvable and I will be happy to help you with that. First of all in order to install active x into your Mac OSX computer, you need to ensure you have internet explorer installed in your computer. If you haven't done so, you can simply go to their website; and download the compatible browser to your computer.
Once you find the compatible browser, you can then begin the process by downloading so that you can install;
Once you download, you can then start the installation process;
Once you install, you can then run the application from the start button;
When you open the browser, go to Preferences from the top tool bar.
Click on Web browser from the list of options.
Click on Web content and wait for the new window that appears.
Look for Active content option and click on it then click on Enable scripting.
Click on Ok then Refresh to get the browser to restart and apply the new settings.
This should work.
I hope it solves your query.
Notifications
