How can I install Dell Stage Remote in Android
Hello Techyv Guys,
How can I install Dell Stage Remote in an Android phone, how does it work with Dell PC, Please do the needful for explaining about Dell Stage Remote and its installation and usage along with features.
Thanks,
Brady Collins
Answered By 5 points N/A #159863
Hey Mr.Collins,
The dell stage is a new software from Dell inc. It can be installed on any android device with android 2.2 or above from the Google play store. Go to the following link:
https://play.google.com/store/apps/details?id=com.arcsoft.stageremotehc
To use the app to its full potential you need a Dell computer with stage pre-installed on it or DNLA device – tv,speakers,etc
The app will allow you to play content stored on one of the devices on another device- given that both of them should be connected to the same wi-fi or any other network you have. For example: you can select a movie to be played on the DNLA tv or stage enabled laptop downstairs while you are working on your android phone or tablet upstairs.
The stage software will also allow you to use your android device as a remote control for your  Dell computer – allowing you to start stage tiles or other apps on your computer from your android device itself.
Plus the app has supports Noisey, Zinio, Blio, and Hulu and also Flickr and Facebook integration.
The app though is averagely rated by most users as its performance is not top – notch.
Still, it is an innovation worth trying out.
It works on windows 7 OS.
