How can i install driver’s in my computer
Hi dear,
First go to Start button. Then go to My Computer option and right click then select Properties. After selecting Properties go to Hardware and then select Device manager. When you select device manager you can see here you're uninstall driver’s. Now you insert Universal driver CD and then right click at uninstall driver’s and then click update driver and select path as CD room. Now after some time your driver is starting installation. Ok.
The drivers needed by Windows don’t come in one package. It doesn’t work that way. When you install Windows on your computer, the operating system installs its own sets of drivers for the different devices in the BIOS or CPU. Some of the drivers that Windows installs are for the video controller, the hard drive, the clock, the printer, game port, USB port, mouse and keyboard controllers, communication ports, and others. It’s too many and too complicated to enumerate them all.
Installing a separate device either PCI or PCI Express type requires installing its own driver. For example, if you attached a network card in one of the PCI slots in the CPU, after the system has detected the new device, Windows will ask you to install the driver for the new found device. At this stage, you need to run the setup file for the network card to install its driver and for the device to work.
Hi Muhammad Tanveer,
Thanks that you have shared your problem with us.
Dear it is so easy to install drivers on your computer.
Just go to this website.
https://www.driveridentifier.com/
It will provide you a software.
Download and install that in your computer. It will scan your computer for drivers.
And it will take you to the drivers download page. Simply download your all drivers from there. Install them and enjoy.
Happy computing.
There are many ways to install drivers in your computer. If you have the installation disk with you, just insert it on your optical drive and then run the setup.exe. Or you can also go to your computer's manufacturer website to see if the drivers you need are available from their website. It is best if you mention the model of your computer or the motherboard so we can help you find the drivers you were looking for. You can also install drivers if you have save the installer in your USB flash disk. Just insert it on your USB port and then run the driver.
