shoyeb666
1000 points
Posted on - 06/21/2011
I have a personal computer built with intel micro processors. But from my childhood I am Mac lover.
How can I install Mac OS specially the leopard edition in my ordinary PC.
As far as I know, my configuration will support Mac OS.
But I would like to know the process of installation of Mac operating system.
How can I install Mac OS in intel PC?
Hi! Good day!
Actually MAC OS is exclusive apple design but I have heard rumor in the internet that Mac has partnered intel to make a desktop MAC OS. There is a way to install MAC on Intel.
System requirement to install Mountain Lion 10.8.2:
2 GB of RAM.
Minimum Intel dual-core processor.
8 GB of available space.
You need a Unibeast and a Multibeast (dl it in you need to register).
You must have an access OS X system borrow you friend's MAC.
Must have a Mountain Lion 10.8.2 installer just click this link to DL. https://itunes.apple.com/us/app/os-x-mountain-lion/id537386512?mt=12 and a 8 GB BOOTALBE USB. You need to make the USB bootable to run the MAC OS Installer.
UniBeast – Helps you create a Bootable USB for installation of Mountain Lion OS X 10.8.2.
Using you friends MAC book, you can copy there the UniBeast for the installation of Mountain Lion OS X 10.8.2.
Then install just make the USB to booth on your PC. Then follow same procedure on install mac. And again copy and use the Multibeast on your USB for driver installment in your newly modified system.
I hope this helps.
