How can i install OpenVPN on Linux?
Asked 2 weeksago in Linux Can somebody give me some clear explanations about how to install PHP from source on a Linux machine?
Hi Kanck,
To install the OpenVPN on Linux. You can find the complete guideline on website given below:
Here you can download and install the on both server and client machines. Here you will find the complete tutorial about OpenVPN.
It may help you. Thanks!
To install OpenVPNÂ on linux you need to have the installation package. The OpenVPN executable package should be installed in both client and server machines. Using Linux, the easiest way to install is to find an existing binary RPM file for the distribution package. The RPM file can be build by typing:
Once you have the RPM file, run the installation using:
An existing installation can be upgraded by:
The dependencies if you are building the RPM file are:
Thank you.
