I have several pictures, some of which have been retouched for better quality. I wanted an all inclusive platform which I could use to share the photos and came to Acdsee 4 Pro. How can I get the free plugin per Acdsee 4 Pro to improve the application functionalities? Thanks in advance.
How can I install the Plugin per Acdsee 4 Pro?
Hello Gwendolynhunterr,
You need to add “ACDSee Pro 4 RAW Plug-in Update” plug in to fulfill your requirement. You can get this plug in from the official site of the acdsee. You can find the update in the following link of acdsee website:
https://www.acdsee.com/en/support/acdsee-pro-4/update/raw
You can also try another software called "Picasa" of Google. It is also with the rich features of image management.
Hope it will help you.
Hi Gwendolynhunterr,
You want to retouch your photos and you want to use Acdsee 4 Pro for this. Acdsee 4 Pro is an image organizer, viewer and image editing software. There are many tools as like Acdsee 4 Pro. But as you want to use Acdsee 4 pro, you can download free Acdsee 4 Pro from the below link.
The link is: Acdsee 4 Pro
You also want to share your photos in an inclusive platform. I give you some best platform for sharing your photos. These are given below.
1. SmugMug Your Photos Look Better Here – Photo sharing but doesn’t offer free membership.
2. PhotoBucket Well organized, easy and adding music for slide show.
3. Picasa Google’s fast, automatically finds and stores photos from your PC.
4. Flicker Popular, widely used and upload 100 MB per month with no limit storage.
Now try to reach your mission.
Thanks,
Taylor
