How can I install Proofing Tools for MS Office?
After installation Office 2007 when I typed some text in MS Word and tried to check spelling & grammar, the following message showed on the monitor screen.
“Can not find Proofing Tools for English (U.S.). If you have proofing tools,try installing or reinstalling them. Contact your local reseller to obtain office proofing tools”
I re-installed MS Office 2007 but the message again appeared upon the checking of spelling & grammar. How can I solve this problem and where can I install it from?
Best Answer by Rennier Lean
Answered By 0 points N/A #114936
First is you will have to download the Microsoft Proofing Tools.
  • If your on the website click the download link, you will then directed to another page then a dialog box will open.
  • Download the link in the preference of your OS installed in your system.
  • When clicking the link an option will pop-up “save File” click ok and the download process starts, and it will be completed depending on your internet connection maybe less than 5 minutes.
Once done find the location of the file that you have just downloaded and install the Microsoft Proofing Tools by double clicking it. You will have just to follow the instruction during the installation process.
Answered By 0 points N/A #114937
You should install your MS Office 2007 again. If your MS Office software installed rightly you will not receive any error message. How would you install MS Office 2007?
After proper installation of MS Office 2007, you should to go to Menu bar. Find there Tools menu and click on it. Find Spelling and Grammar: English[US]. Resume it. Change it. It will proof your written and save document in the MS Office 2007. In this way you are capable to proof-read to your document. You may have find spelling check.
