How can I install proteus 7.7 version in xp?
I have Proteus 7.7 and my operating system is windows XP, every time when I click setup to install but it does not work.
I have tried several times but the result is same.
How can I solve the problem?
The Proteus Design Suite is wholly unique in offering the ability to co-simulate both high and low-level micro-controller code in the context of a mixed-mode SPICE circuit simulation. With this Virtual System Modeling facility, you can transform your product design cycle, reaping huge rewards in terms of reduced time to market and lower costs of development.
Proteus 7.7 works in Windows XP as well as in other versions Microsoft Windows Operating System.
If after all several process of installation you got no luck on installing the software, you might download a file or installation file that is corrupted.
Instead of download the software on the same downloading site, why not to try to download the installation software from any other site or better to download the software system support site to make sure that you are downloading a valid and reliable installation files. After downloading from a reliable source, install the downloaded application.
Checking the bit of your computer or operating system may help you also solving the problem. Some software does not work in 64 bit or vice versa. Check for the compatibility of the software.
Before installing Proteus 7 and any other applications, make sure you have reviewed the system requirements to make sure your computer is perfectly eligible to run the program. Proteus 7 supports Windows XP, Windows Vista, Windows 7, and Windows 8. For Windows 7, Windows 8, and Windows 8.1, try troubleshooting using compatibility mode in case you encounter a problem with the installation.
It requires Intel Pentium 4 or faster processor, 256 MB RAM, 250 MB free hard drive space, and video card with OpenGL 2.0 support. If your video card doesn’t support OpenGL 2.0, the program will still run but only in Windows GDI mode. When this happens, the display is handled by the operating system or Microsoft Windows instead of the graphics adapter.
In this case, several of the features of the program will not be available and you might experience an adverse effect on the performance. If you are using a built-in video card from Intel, better add a separate video card. Labcenter Electronics Ltd. recommends using either NVIDIA or AMD ATI as graphics adapter. If you verify your system is fully compatible, try running the installer with an elevated privilege.
To do this, right-click on the Proteus installer, point to “Run as”, and select “Administrator” in Microsoft Windows XP or select “Run as administrator” in Microsoft Windows 7.
