Hi there!
I have been trying to install RH Max module plugins but every time I tried it did not complete the installation. Finally it managed to run all the way and that was when everything went wrong. Now I realized that the application is not working properly and I have no idea how to reverse back to the previous position. The plugins are tested and have been used yet I am not able to run it successfully. Thanks.
How can I install RH Max module Plugins?
It’s not clear what application you are referring to but if you want to install a plug-in, make sure the plug-in is compatible with the program. Check that the version of the plug-in supports the current version of the program you are using. If the plug-in is a download, go to its download page again then check the specifications or the system requirements.
Check that the version of the plug-in supports both your operating system and the version of the program you are using. You cannot use the plug-in and it will not work if one of these two factors is not supported. If the plug-in came with an installer, uninstall it from the Control Panel or using its own uninstall program.
