How can I install softmaker office pocket?
Hi guys,
I have a pocket PC I want to install softmaker office for it. I am not reaching the website from where I can download this software? Please help me regarding this and also let me know that which softmaker office is suitable for pocket pc.
Thanks in advance
Answered By 240 points N/A #178479
Hi Gregory,
I believe I can be able to help you solve this question in the best way possible. You can be able to get the softmaker software easily from the internet by going to the website; http://www.softmaker.com/en/download/trials
Most of the software versions are usually sold. Here you will only be able to get the trial version free. This is a suitable softmaker version for your pc since it is the latest version.
You can follow the prompts to install, ensure you don't have any other software's installing and that your pc has all the required specifications and memory for the installation of the software.
Once you install your software, you can then restart your pc for it to function properly
This should help
Thanks
