How can I install Ubuntu in my computer?
you can easily install ubuntu in your computer. If you have an ubuntu CD, start the system with the CD in the CDROM drive. At first it configure your system requirements to run Ubuntu. If the system meets the required configure and you want to install Ubuntu double click the install icon. Then select the language you want to use. Click the Forward button, select your city and time zone and then click Forward, select keyboard lay out then Forward. Select ‘’Guided-use entire disk’’ you can also specified the partition size. At last click the install button. After install Ubuntu restart the computer. Thank you all.
Hello Stomjonson,
To install ubuntu on your computer, your will first need to get the ubuntu version that you want either by downloading online or getting a CD that has one. When you download online, you will have to burn it on a CD and make it bootable, or you can make it bootable on a USB drive.
Execute the bootable setup from the CD or USB drive, and install on the same partition as windows so that when you boot the machine you can either choose to boot from windows or linux: called dual boot.
__
Regards
Lee Hung
