How can I Install VGA Driver
I installed Windows 2000 myself first time.
When the desktop of my computer appeared the message was showed your “VGA driver not installed”.
I followed the message to install drivers but after completion of the procedure of installation windows again tried to detect my VGA driver and required CD or source of the driver.
What I should do to install the driver of VGA.
Best Answer by Heaveneser Hanes
Answered By 0 points N/A #115532
Here are the steps in installing a VGA driver in your computer:
Click the start button on your computer then point the mouse cursor to control panel, double click the device manager, once done select display adapters then right click on the active driver, then select properties, manufacturedr of the video should be in the list on the general tab.
Now you will have to go to the manufacturer’s website then search the adapters model and name number. Download it to a folder in your computer, once done you will have to go to the Device manager again, and you will have to uninstall the current VGA Driver just simply follow the on-screen instructions.
After that, right click on my computer icon then select explore then find the way where the VGA driver is saved. Right click on the driver then click on run administrator in order to install the new driver into your computer, once done just restart your computer.
Answered By 5 points N/A #115533
Hi
In these kind of issue you me download first the driver of VGA video card to resolved this kind of issue.
How to download the VGA driver?
1. If your VGA is built-in to the motherboard, find the name of the motherboard and number.
Example:
The name of your motherboard is ASUS P5GC-MX, and on the Google website type in the search box: ASUS motherboard P5GC-MX driver  then download the VGA driver.
2. If you can’t do it… use Driver Genius software to update your VGA.
Thank you, hope its help
Answered By 0 points N/A #115534
Solve
Hello Mr. Georgewin
I read your problem. But I Think this is not very critical problem. Now I try to give some workable solution for your problem. Please read the below solution and work step by step then I think you will cover up the problem.
First you have to select the start button then you have to go to control panel double click on the device manager then select display adapter then right click on the active driver then select the properties then manufactured of the should be in the list.
Then you have to go to the website of the manufacturer’s and search the adapter model, name and number. Then you have to download it into a folder in your computer. Then you have to uninstall the current VGA Driver.
Then find the folder where the VGA Driver is saved. Then right click on the driver and click on run administrator for install the new driver into your computer. If it is done then restart your computer.
I hope your problem has been solved by these solution.
Thanks from
Arafat hossain
Answered By 0 points N/A #196505
Hello Dear,
Thanks that you have shared your problem with us.
It is very simple to install your VGA driver into your computer.
Kindly connect your computer with internet,  go to www.driveridentifier.com.
There will be a little software called "driver identifier" download it and install it.
It will scan all your system for drivers and then it will redirect you to the driver download page.
Download your desired driver and install it.
And enjoy.
Happy computing.
Answered By 0 points N/A #196508
VGA comes pre-installed with all versions of Windows. But if you are having issues on the VGA driver, try to go to the Device
Manager and then right- click on your video adapter and click to Uninstall.
Restart your computer and you will be prompted with the New Hardware Found wizard.
Click Next and then search for the suitable driver and then click Next until you finally search the required driver.
Another way is to check on your computer model and motherboard brand to specify the required VGA driver needed.
Some manufacturers have a support page where you can download drivers needed for your system.
