Hi guys,
Can someone help me. I am trying to open Yogbox 1.8.1 and
when I select "yogbox installer", there is a message that appears like this:
C:UsersUserAppDataLocalTempRar$DI68.552mods doesn't exist.
C:UsersUserAppDataLocalTempRar$DI68.552conf iginit_text.txt doesn't exist.
C:UsersUserAppDataLocalTempRar$DI68.552conf iglogo.png doesn't exist.
Can anybody answer this please?
How can I install Yogbox 1.8.1
Did your download complete successfully?. I feel that the download has not to all the files that are required by the installer. I would like you to re download the software and then perform the installation tasks. If some one else has the installed software, then copy the missing files to the missing directories. These directories are not currently created on an incomplete install archive. You may have top manually create those directories. The download is very usual and inexpensive. You may find the same problem. If so, the copy the folder to another directory and then retry. Else use an updated version.
