How can I join HD-TV to g-card with sapphire HD pro installed
Hi there,
The sapphire HD pro I have installed in my g-card came with an s-video output. The card has the colors blue and green on it. Now, I want to join it to my HD-TV. Can I go ahead with the union so that I could use my vista media center? What am I missing here? Thanks for helping me out.
Answered By 0 points N/A #140106
Hi Janetdschall,
If you have sapphire HD 2600pro installed, you can go ahead with the union and join your g-card to your HD-tv. You can simply do this by connecting the cables to the respective ports. I don't think anything is missing. If there's something you'd need, the manufacturers would have provided it.
If you installed other versions of sapphire HD pro, you can also go ahead with the union and see if it works.
I hope I've answered your question.
