adriane
Posted on - 11/03/2011
Hello!
My network consists of four Win 2000 Professional work station.
How can I know whether the network is using TCP/IP or NETBUEI.
The pinging of each work station is not doing.
Anyone please clarify it???
Thank you….
bobii
How can i know whether the network is using tcp/ip or netbuei
Generally, win 2000 uses tcp/ip for network. To determine whether it is using tcp/ip or netbuei, you have to do some steps in your system.
First, go to the control panel and select the network places(or from internet connections) from there. by double clicking, open it and select the properties from there. There you will see that tcp/ip(protocol) option and thus you will know it is running on tcp/ip. On the other hand, if you do not find such option, you will be sure to know that you are using netbuei.
