How can I learn everything about Micromax dual sim mobile phones?
Hi expert,
I need your help. I need some important information about micromax dual sim mobile phones as I want to buy one. Please, tell me in detail about it especially about its price and new features added. If I want to buy it in India, tell me what I should do.
Thanks in advance
Answered By 0 points N/A #137640
Hello Mr. Browning,
 I would try to answer this question in a very understandable manner. I am presently using Micromax a57 (superfone ninja) since last 6 months or so and to be frank i am not quite happy with the way it functions.
First thing to be noted is that as u run multiple applications simultaneously it forcibly closes all running applications making u lose any access to the applications. Micromax mobiles are designed in a creative way, so the feel and look is good.
In the long run, u will start hating this device before u do so with devices from Samsung, HTC and others.
I hope this has been informative for you.
Thank you
