How can I learn iPad tune up process?
Hi expert,
I’m facing with my iPad as it is working very slowly. So, it needs to be tuned up I think.
But I don’t know how to do it. Please, tell me the iPad tune up process in detail as I can do it easily.
Do I need any software to do it?
Thanks in advance
Best Answer by James C Montes
Answered By 50 points N/A #171407
Hey Bennie,
I personally have my own iPad and when it starts acting slow heres a few ways I've used to fix it.
1. Close applications you are not using by double clicking the home bottom, holding down the app and simply just deleting it from recent used.
2. Rebooting the iPad.
3 If that still doesn't work then you can try deleting all aps you do not use and that should fix the problem.
Thanks for reading,
James C Montes.
Answered By 50 points N/A #171408
Hello, Bennie S Easter
Hope you are fine.
The iPad safari app can slow down your iPad. So you can clean out your cache. Though is not a good tune up practice, but it’s a great way to speed up your iPad.
Tap Settings >Tap Safari > Tap Clear History, Clear Cookies, Clear Cache
Otherwise you can give your iPad a good restart, reboot or restore.
See how to restart, reboot or restore.
Hope you will get your answer.
