How can I learn Windows oem activation technique easily?
Hi expert,
I want to learn many things about computer. Now I am trying to learn windows oem activation technique. But I am getting failed again and again. So, I need your help. Please, give me instructions very as easily as possible so that I can learn it easily.
Thanks in advance
Best Answer by Franklin Alejo
Answered By 50 points N/A #145533
Hello, Maria Trienity
Hope you are fine. I think I can give you a solution. So don’t worry.
You should be happy to hear that I can give you a video link so that you can learn it very easily.
See the video
There you will get everything you want to know.
Hope you will get your answer.
Answered By 0 points N/A #145534
OEM stands for Original Equipment Manufacturers. It can be activated only one time and it helps to associate BIOS of PC with Windows OS. Activation of OEM happens before the PC arrives to the client, this is why there is no need for the end user to do anything related to the OEM. The Windows OS copy that is installed by the OEM is unique, meaning that it is only for that computer specifically.
For activating the OEM by yourself, you have to follow below steps as per your Windows OS version:
Be careful to install the right ".iso" image referring to your Windows Operating System and processor.
A) XP
For XP Home services:
GRTMHOEM_EN.iso / en_windows_xp_home_with_service_pack_3_x86_cd_x14-92413.iso
For XP Professional services:
GRTMPOEM_EN.iso / en_windows_xp_professional_with_service_pack_3_x86_cd_x14-80428.iso
1. Create a backup of the existing OEM. You may find the needed files to back-up under system32.
Backup these files: OEMBIOS.BIN – OEMBIOS.DAT – OEMBIOS.SIG – Catroot{F750E6C3-38EE-11D1-85E5-00C04FC295EE}OEMBIOS.CAT
2. After backup finished, start with the creation of .cab
3. New .cab created files should replace the existing OEM files (/i386)
4. Save the activation files under system32 (.dbl and .bak file)
5. Install the COA/Authentication key
B) Vista
For vista sp2 64bit use "en_windows_vista_sp2_x64_dvd_342267.iso"
For vista sp2 32bit use "en_windows_vista_with_sp2_x86_dvd_342266.iso"
For Win-7 Ultimate 64bit use "en_windows_7_ultimate_with_sp1_x64_dvd_u_677332.iso"
For Win-7 Ultimate 32bit use "en_windows_7_ultimate_with_sp1_x86_dvd_u_677460.iso"
1. Perform backup via ABR
2. Install the COA/Authentication from the beginning
3. The key should not be inserted if required during the installation process
4. After installation finishes, use ABR to restore the files you saved to step 1
