cooky
Posted on - 09/24/2011
I have a small internet cafe. Every time people uses the cafe they change something like wallpapers, proxy setting, password… even they install illegal softwares. I limited their user privilege to standard user but they still manage to spoil something. the computers are connected in homegroup how can I avoid further changes?
How can I limit users not to change my computer settings?
There ways to set your computer into full restriction. The user can only play and browse the Internet and nothing else. You will need to log-in to the Administrator and enable the applications that you want to let them play. This can be done by disabling application, hide files and folders not used for Internet and gaming. Log-in to the administrator and disabled components not in used for Internet cafe type of computer. When computer is turning on, press the F8 key to log-in to safe mode. Once in this stage, you can disabled the desired files and folders. You have the full control of everything, applications and other important software that you want to disabled while they are log-in.
You can limit what software and application installed in the computer specially the functions and can be viewed as read-only access.
Go to the system registry and disabled the components you don't want to be viewed.Â
