diazgracee
Posted on - 09/13/2011
Hello Experts, I m trying to install MetaFrame XP this morning, and I received the following error message that I cannot load the XP configuration Support DLL. I need your help how to fix this.
Any solutions is greatly appreciated so much.
Thanks
Installer Information
Cannot LoadXPConfigSuport.dll
How can I load XPConfigSupport.dll?
This error messages shows which .dll is missing. It calls “ConfigSuport.dll”.
It is missing may be for one reason but there are many reason for missing this .dll file. It is a dll file that uses more than one application program at a time. So when you install software or run a program they always check this dll file. That’s why its so important. Also for this reason this dll file is overwritten and restored many times by running programs. Some times they can not restore it perfectly. When it happens your antivirus indicates it as a corrupted file and removes it at the time of scanning your computer.
To solve this problem you need to install this missing dll. You can download “FixMyDLL” Software. Here you can find it Download Link this will reinstall your missing ConfigSuport.dll
