Hi guys,
How can I locate need for speed setup file free download? After the installation process I cannot find the shortcut icon key in the desktop, I have to find the correct location of the need for speed game setup to manually run the program. I need your guidance.
Expecting some help, thank you.
Hi Travis Nelson.
After the installation, unless you find a desktop icon, you can find the setup file in program files. If you use a 32bit computer, you will find it in C -> program files -> Need for Speed Most Wanted -> setup.
If you use a 64bit OS, you will find it in C -> program files(86) -> Need for Speed Most Wanted -> setup.
Good luck.
You said that you installed Need for Speed in your pc. But you can't find the application file. I think when you installed the game you didn't select the desktop icon. However, you can find the setup file in the folder where you installed the game. You can reinstall the game and select to have a desktop icon.
