How Can I Make Changes To A PDF File?
I have some documents which are in PDF format and I am unable to edit it in Acrobat Reader. How do I make changes to a PDF file?
To edit PDF files in Acrobat Reader, you will need to install “Edit PDF files” extension. After installing the extension, you will be able to edit PDF files by enabling the extension. Click on any text or image you wish to edit. The document will reset itself automatically. You can even edit headers, footers or watermarks using this extension.
If you have some PDF files that you need to edit, try using Foxit Reader. It supports Windows 7, Windows 8.x, and Windows 10 both 32-bit and 64-bit. For Microsoft Office integration, the latest version at the moment supports Microsoft Office 2007 and higher. It requires 1.3 GHz or faster processor, 512 MB RAM, 1 GB free space, and 1024 x 768 minimum screen resolution.
For Mac users, it supports OS X 10.9 until 10.13. If you can’t use Adobe Reader for a particular task, Foxit Reader is one good alternative. It doesn’t only allow you to open PDF files but also use it to create PDF documents or files. You can create PDF files with your Microsoft Office Word, Microsoft Office Excel, and Microsoft Office PowerPoint with the help of the add-ons.
It allows you to encrypt and sign PDF files. You can sign your PDF documents with your own handwriting or use eSignature.
