How can I make hex textures?
Hello experts,
How can I make hex textures? I would like to know the best software that will allow the user to create hex textures or any tiling styles. Name those specific software and also give some comments and compliments after using the software. Thank you.
Best Answer by JOY Schilling
Answered By 5 points N/A #182862
I got a best news for you. You want to draw hex texture, here i am telling you how it is possible. There is a software called HexDraw, which is used to create hex texture, different terrain features like roads and hexes in plain colors. Hex Draw is an easy to use for designing and graphical techniques. This software also provides some default textures and you can create your own also.
Hex texture-HexDraw, which is used to create hex texture, different terrain features like roads and hexes in plain colors
Here is link to download a trial version of HexDraw.
Answered By 0 points N/A #182863
I came across this software that can be used for works on hex texture and tiling styles. Try visiting this link https://hex-workshop.informer.com/ which is often used other than Hex Draw.
http://abdio-hex-editor.software.informer.com/ – this software is a hex editor with user friendly interface. It has different features that will guide you through editing works on hex textures and tiling styles.
