How can i make my web page layout by painting
Please tell me how I can make my web page layout by painting.
What software can I use for this kind of work ?
You can use the Adobe Photoshop CS3. You may create a new document 1200 pixel by the 1160 pixels, with a white background. After creating the document, you must setup the guides that aid in keeping the layout from 850 pixels wide. Go to the view , choose the new guide. You must setup the guide. Enter pix to 1025px for set to the vertical.
Now go the fill background ; use the radial gradient to set the foreground color to a white color and the background to a light gray color. Make sure you apply the gradient to the background layer and just select the type tool in the top-left of your corner.
You wanted to paint the layout of your webpage. Anyway at this moment, you can install a webpage layout painting software. You can save your webpage at picture menu and click on open ; you will have to find the paint menu. Here you may choose several colors to paint your webpage layout. Also you can select font to write something else.
You desire to use Adobe Photoshop CS4 software for your immediate need.Â
So,start your invention to draw painting specially then you will learn more about it.
You can download free software for what you want.
