How can I make a negative of a picture?
If you are using windows 7 or vista it is so easy job. Right click on the image then select “open with” and select “paint”. Now your picture will open in the paint, application.
Just right click on the image and select invert color. That’s it you are amazed. On the other hand if you are using XP or earlier than again open the picture with paint. Then go to top menu and select image in the drop down menu click on the Invert Colors to change the picture to look like a negative.
That is so amazing isn’t it?
Ok that all.
There are lots of ways that you can do this. There are lots of software’s that can help you to do this thing.
My recommended software is Photoshop. It changes the picture into real negative look. Here is a video tutorial that I found that explains how to do it in easy steps.
If you follow this video you can do it very easily.
Pain shop is software that you can create a negative of the image.
I found out a web site that provides an online picture editing environment.
Here is the link:
It is easy; you don’t need to install any software to use it.
Thank you.
Notifications
