I am using this desktop inventory system the whole day and I don’t want other programs or windows to open, is there a way to make the said program in Windows XP always on top?
Please reply asap.
Thanks a lot.
How can I make a program in Windows XP always on top?
There is no default program from Windows XP to make your application on top but you can download some tools that help you achieve what you want. You can download Always on Top application were your chosen application will be always on top of the other applications.
You can also try power menu just like Always on Top Application it makes your chosen application above other applications. Deskpin is also a good application on making your program always on top, you just have to grab a pin icon on Deskpin and your application will always be on top.
Always on Top Download: http://www.fadsoft.net/AlwaysOnTopMaker.zip
Power menu Download: http://www.abstractpath.com/powermenu/
Deskpin Download: https://deskpins.en.softonic.com/?
