How can i make secret word template in office 10 ?
I need to make a secret word template. The template should look like containing classified information. How can I create such a template in Microsoft Word10 ? Can anyone help me. Thanks.
Hi Beeky Kaitlyn,
Locate or generate a document.
Strip out any text that doesn’t require being in every document.
Decide the Save As command from the File tab menu.
From a name for the template in the File Name text box
From the Save as Type drop-down list, select Word Template (*.dotx).
Click the save button.
Close the template by preferring the close Command from the file tab menu.
Thanks
Hi Beeky Kaitlyn,
There is no standard format/template used to create classified documents, as long as you place security mark/classification of your customized document, then it can be considered as classified documents.
Microsoft Office 2010 also has features in protecting your documents (Open Office2010, Click FILE/INFO/PROTECT DOCUMENT/chose your preferred restrictions)
Click the link ( http://www.afsbirsttr.com/Publications/Documents/Author_Guide_Oct09.pdf ) this serves as a guide on how to create a professional looking classified template, scroll to page 18)
Hope this helps,
Llison Janneya
Hey,
As you have stated above you want to know how you can make a secret word document. Well I personally believe that it will be a lot easier for you to understand to do so through a detailed procedure. So, I am providing you a link where you can get all you want. Visit Steps to secret word document.
I hope this will solve your issue and anything else you want to know considering that issue please let me know.
Thanks & Regards,
Gillam Janetj
